Sqwealing Clutch???dont know what to do.
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
bandytZ24
Car: '85 720 Pickup Z24
Just replaced the stock elec. carburetor with a Weber 38, drove it, now the clutch makes a sqwealing noise...all the time. In neutral, and in gear...I know I need to R&R the slave cyl but not sure why, or where this noise is coming from.......any ideas anyone???????????????
PEZi
So, it didn't make this noise prior to the install? Because the carb and clutch have nothing to do with one another as far as that is concerned obviously... so it leads me to believe it is either not the clutch, or a completely unrelated problem. Can you describe the sound more?
bandytZ24
So, I troubleshot the clutch issue, thinking it was the clutch master cyl (R&R), then cleaned the clutch damper, and R&R'd the slave cyl too, bled the system. The fork stays pushed against the clutch spring. Not sure what to look at next.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
The pressure plate may have failed.
bandytZ24
pressure plate is good...but theres nothing there to keep the fork against the slave cyl...what am I missing?
bandytZ24
does anyone know where I can find some diaghrams??? or pics
bandytZ24
Solved my problem, wasnt even transmission related.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
What was the problem? We post info to help each other.
bandytZ24
Ran a vaccum line for the carb to the crankcase breather inlet on the valve cover, i felt like an idiot. will post pics soon as the sun comes out.
Return to “Datsun 720”
