squeeking sound from the front!!??
Q45dude
Car: 94 Q45
Hi,
I have a 94 Q45 and my car periodically will make a squeeking sound coming from the front (either left or right) especially when going over a bump. Sounds like some kind of suspencion issue. Is it time for new shocks? struts? lower/upper arms!??
thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Maintenance history, please? (Read the sticky.)
When were tension rod bushings and upper links last done?
Q45dude
Car: 94 Q45
They're believed to be original. I doubt previous owner every changed them. But why would it go away and come back again in a few days or weeks?
Its your upper links.
96Qowner
Car: 1996 Q45
Yep, it's upper links. I'd strongly advise you to also do the third link/kingpin, too, an extra $200 in parts. The uppers are about $200. As maxnix suggested, your tension rod bushings are also probably shot - not making the noise, but they just don't last the life of the car. *Sigh*, and your shocks are probably shot, too.
You might want to think about biting the bullet, and doing it all. You'll be amazed at the improvement.
Q45dude
Car: 94 Q45
Thanks both.There goes the paycheck AGAIN!! The shocks I defenitely feel need to be replaced.But I'll start with the upper links as suggested.
Thanks guys
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45dude wrote:Thanks both.There goes the paycheck AGAIN!! The shocks I defenitely feel need to be replaced.But I'll start with the upper links as suggested.
Thanks guys
Shocks with all rubber from Joe.
http://www.infinitpartsusa.com
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
I'm getting a sound too. Not really a squaek, more of a creaky/groan coming from the front passenger side when going over bumps and really just standard driving. It was something that I noticed back in February, but it went away and was never heard from again. Then, last week, i noticed it again.
Just curious as to what it could be.
Apparently Murphy felt it appropriate to kick my arse with his laws in the last 3 weeks. Everything imaginable is going wrong right now.
96Qowner
Car: 1996 Q45
Haitian_King wrote:I'm getting a sound too. Not really a squaek, more of a creaky/groan coming from the front passenger side when going over bumps and really just standard driving.
Yeah, "creaky/groan" is a good description of the sound a worn upper link makes. Passenger side usually goes first. And I recently discovered that the third link/kingpins are prone to bending which throws off camber and caster - no adjustment, so you have to replace them too, to get alignment in spec.
Haitian_King
Bloody hell.
*Hits the search button and is appalled.*
