squealing sound
ben01
i have a 01 Pathfinder, 98 000 km, not too long ago in very cold weather it started to squeal, an when warm it almost disapears, i changed the strap and the pulleys, still squeals,it sounds like a bearing or something and it is in the pulleys area...
need some help!!
Ben
Modified by ben01 at 12:51 PM 2/17/2007
vliou
Join the club. I'm taking my car to be serviced on Monday b/c the issue scares me. We'll see what's what. I don't know much about the inner workings of my car. I know it's not the belt b/c those are 6 months old. It gets louder as the engine revs higher, and I think it's a pulley this time...but at only 71,000km, I'm guessing...
Axelpkt
Car: 2002 Nissan Pathfinder 5spd
Mine started squealing after I changed he belts. They squeal horribly in the cold, but, sound fine after a min or two
Pisspi
Car: 06 & 95 Pathfinder SE's
ben01 wrote:i have a 01 Pathfinder, 98 000 km, not too long ago in very cold weather it started to squeal, an when warm it almost disapears, i changed the strap and the pulleys, still squeals,it sounds like a bearing or something and it is in the pulleys area...
need some help!!
Ben
If it still says Nissan on the belt, then it's time to change.
I've had brand new belts squeal on me after 2 weeks. All I did was check the tension and sprayed some belt dressing and the squealing stopped.
redhat-z
Go buy a stethoscope from Autozone or Harbor Freight and start poking around to narrow down which pulley it might be.
ben01
Both pulley have been changed, and belt changed twice.... still have this anoying sound,
broken
yea i to have a sqealing sound changed belts and bearing in the compressor pulley . im thinking its the alternator
ben01
let me know what was it for, you, my mecanic can't see what it is, and i don't wanna spend 80$ an hour at the dealer.....
vliou
Turns out to be the harmonic balancer and the clutch fan pulley. When the engine is warm, wear a pair of gloves and stop the fan. Wiggle it around, see if the squeal stops. It did fo rme, and when I replaced it, all was well.
ben01
how much did it cost you?
vliou
1k with 14% tax and labour
pathman87
Car: 2001 Nissan Pathfiner 4WD Silver
i had the same problem a month or two ago. even if you have new belts it can still squeal. check the tension on the belts. and also make sure your defrost isnt on during start up. that can also cause the squealing in cold weather.
USMC
are those parts easily accessible and able to be worked on? i don't have 1k to drop on getting it fixed. my car has the same problem. squeals when it starts up, and stops as soon as i apply pressure to the accelerator.
vliou
Try this: When it squeals, turn off the engine and then turn it back on. If it stops, you have a belt problem. It's just not tight enough...
The reason this works is that the pulley is still moving when u turn it off, when u turn it on, it locks properly w/ the pulley.
nap77
Car: infiniti qx4
i have a 97 qx4 and have the same problem, new belts replaced pulley still squeels. not my steering went andthe mechanic is telling me my harmonic balancer needs to be replaced, hope it stops the squeeling too
Modified by ben01 at 12:51 PM 2/17/2007[/QUOTE]
ben01
here in montreal, weather is warmer, my truck does not squeal anymore.... is my Pathy just allergic to cold??will see in november!!
