sicwitit »
https://forums.nicoclub.com/sicwitit-u90139.html
Fri Oct 09, 2009 1:35 pm
I had the same problem, I went to autozone, bought some belts, then took them to Nissan, and compared them to the Auto zone belts....needless to say, I took the autozone belts back.
Oh, I should mention when I replaced all the belts, I had a problem with one of the tensioner pulleys, I think it was the lowest one on the block. Mine bent when removing/lossening the belt. I took it to Nissan and they told me that alot of Pathfinders have this problem and a new tensioner was $165. I didn't like the sound of it, so I went home and bent it back into shape, and welded some braces onto it. I can't take pics of it now, but I will when I get back in the states and post up a how to I guess. just be forwarned, if you have the same problem when changing your belts out, and you run into that issue, there is an expensive fix that might not solve the problem next time, or a simple fix that will perminatly fix the issue.
JT
