Squeaky SR!!! WHAT IS IT????
Gmans13
Hello again everyone. I got my engine running the other day (w out the exhaust because I need the down pipe flange welded on.) and last night I took my car too drop it off at the shop that was going to do my welding and also align my front end. But anywase the car drove fine the whole way down their (except for the idle problem) when I got to the shop I let it die one me when I was shifting to reverse to back in to a space. When I started it back up I herd the a very loud squeaking noise that I had herd before when I ran the engine but only if I let it allmost die. It didn't sound very nice so I just decided to push it in the space and worrie about it the today. I had a look at it today and started her back up breifly and still the same LOUD squeak. I forgot to mention that the squeak will go away if I rev the engine over 2500 rpm or so. If some one could help me out that would be totally sick! Thanks:help :help :help
implict
sure its not any of your belts?
Gmans13
I only have 1 belt (NO AC or PS) it could be that but....
implict
well if it stops when u rev.... i think that would be ur prob.
Gmans13
hmm...the only reason I don't think it is the belt is because it dosent sound like the typical startup beld screach. It is more of a screach every time the engine turns over. Any suggestions on what I could do to my belt to try to get it to stop?
matt240det
spray the belt with wd-40 and see if it still pursists
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Just reach in there with a wrench, and tighten the friggin' belt! My Honda passport did it, took 2 mins to make the dreaded scream go away.
sr20det
Car: Drifting, draging, silvia projects
tighten up the belts more. the belts probably is lose.. my cars squess loud as fack when my belts are loose.. :)
yellow_jacket
Car: 95 240sx
It is not the belt. Check his newer thread out athttp://www.nissaninfiniticlub....14038
