Gmans13 wrote:The engine came out of the clip as a set. I never set the engine directly on the oil pan.The oil pan did have a small dent in it when I got the engine and everyone that looked at it didn't think anything of it but...
Where could I find a valve terrain upgrade and arround how much would that run?
Sorry, i don't know about valve train upgrades. I'd concentrate on what you have for now, and figuring out what caused the oil starvation.
If as you say the bearings are good but the cams are done, Then this indicates that you had oil pressure for the bearings, but for some reason it didn't make it to the head. I'd suggest that possible reasons might be a blockage in the oil gallery going to the head, or lack of oil pressure/volume so it couldn't make it to the head.
Blockage to the oil gallery seems very unlikely, but possible. Lack ofoil pressure still seems like teh most liely candidate. The head is the last place the oil gets to, furthest it has to travel, so low pressure, or low volume this is where it would be missing from first which might explain why teh bearings are OK (there was enough pressure/volume to oil the bearings, but not get to the head).
I almost hate to ask this question, but you did have enough oil in there?
You still didn't tell us if you verified oil pressure before you started it? When you drove it to the exhaust shop was the oil light on? Did it flicker even?
If I were you I'd be contacting the company I purchased it off. Did it come with some sort of warrenty? I'd work that angle before figuring out how to fix what I had.
If you have to fix what you have, buying an incomplete engine, maybe an auto, cheap, might be your best bet. Head, rods, pistons crank etc. are all the same, amd you might be able to seel teh stuff that you don't need, injectors, fuel rail, starter, alt, whatever to get back some of our money.
-Martin.
