yeah that.... you should have just ordered the whole set manrobomatic12 wrote:What is going on is most likely that the accessory belts have loosened and are now squealing when they are cold or under load. You need to tighten them to the correct tension.
I think what crazed32 is trying to say is that it is reccomended to run a overdrive waterpump pulley when you put on an underdrive crank pulley in order to keep the h20 pump running at correct speed.
Yeah im sorry i didnt specify I had both the under and overdrive pulley's done when i had the 120k service done.CrazedZ32Owner wrote:if im not mistaken isnt the over drive pulley supposed to correct that??... check it out on Z1's website they explain it pretty well. From what i understand it is a good idea to both the Under and Overdrive pulleys at the same time
