Squeaky noise coming from alternator area?
oxs1
I am getting a squeky noise coming from the alternator area. Can it be the bearings or do i have to change it?
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Try to narrow it down to see if it is the alternator and not an idler pulley first.
oxs1
As my rms rise the noise gets louder. And sometimes when i rev the engine you can hear it and it kinda sounds like the power steering squeak.
90Q45blue
Car: 2006 Honda Accord EX-L
It's either a belt or an idler pulley. If you can record the sound and post it here, we could probably narrow it down for you. Or you can just take it to a local mechanic and have them take a listen. The belts and idler pulleys are simple jobs any mechanic can handle.
Nick
Q45tech
Sound is just a vibration you can hear..........it's frequency is above 45 HERTZ.
If you know the exact rpm and exact frequency [of vibration] you easily can reverse calculate the exact diameter of what ever is causing the sound/vibration.
Unfortunately a squeel is a complex sound and not a pure tone so you need to display the sound on a spectrum analyser and grapple with the various amplitude peaks.
Or just learn the sounds of pullies and bearings and identify the location with a technicans stethoscope [a thin probe is attached].
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Yeah.....
Sorry I was in a hurry this morning & meant to also type this:
DCB method:
Remove the belts, leaving the innermost one on, start the car & see if you hear the offending noise. If not, remove the inner belt & attach the next outer one, repeat until you determine exactly where it's coming from.
*Obviously* don't leave the car running for more than a few seconds or so while doing this test. It may not narrow them down one at a time, but narrow the grouping somewhat.
Q45tech wrote:If you know the exact rpm and exact frequency [of vibration] you easily can reverse calculate the exact diameter of what ever is causing the sound/vibration.
Now THATS cool info!
As far as my squeal, in the exact same situations in described, it ended up being the water pump.
