NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Jun 09, 2005 2:41 am
The valve cover does sound a bit far fetched. Not sure what your describing with the start issue. As far as rear brakes go, have a look at the pads ,do they look like they are at sensors? If so yes replace them. I recommend you go with OEM pads as they are less suseptable to brake squeek. Also when replacing the pads I recommend you have the rotors machined to remove any glazing. Glazing is pretty much the #1 cause of squeek especially when the brakes are cold [ when first driving after sitting several hours] and again once they get hot from heavy/frequent brake applications. When doing the pads its recommend you apply PBC grease between the shims on the back of the pad, the shims coupled with the grease application help prevent vibration during braking which can eminate as squeek.
