EazyBreazy »
https://forums.nicoclub.com/eazybreazy-u10672.html
Sun Sep 24, 2006 8:36 am
another thing that causes squeaking is dirty calipers, rotors. if you touch the pad surface, and put grease, dirt or oil, you need to clean it off. bedding the new brake pads also makes a huge difference, not only in that, but the friction between the rotor as well.
btw, you should get your rotors turned
