Squeaky belt
phil4watching
Car: 06 infiniti g35 coupe
Can anyone do a write up or could tell me how to change my belt? It's driving me insane. I'm trying to do as much as i can so the dealership doesn't get to rip me a new one. thanks guys
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Did you search?
I think this has been talked about before.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
If you can't find another thread on this, check out the FSM in the FAQ. Also, buy the belt from the Infiniti Parts counter and they'll print you out a diagram
tollboothwilley
all you need is a floor jack, 14mm socket, 12mm socket and a socket wrench.
The pulleys are held in place with the 14mm nut.
The adjustment bolt is a 12mm.
#1) Lift up the front end of the car (set E-brake).
#2)loosen (no need to remove) the 14mm nut on the pulley. (2 pulleys, 1 for each belt)
#3) Loosen the 12mm bolt that adjusts tension.
#4) Remove belts and replace with new.
#5) Reverse to tighten.
DO NOT OVERTIGHTEN. If you hear squealing from belts, belts are too loose still. Re-adjust.
