squeaking under the hood
saeedakobiakov
Car: 03 M45
Hello,i have 03 m 45 with 81k on it.i have squeaking under the hood right where the all the belts are.it used to do it only when it rained, so i put new belts. now its doing all the time.My mechanic said it could be idler or tensioner pulley.Please let me know what i should do.Thanks,caug.
saeedakobiakov
Car: 03 M45
Hello again,looks like i posted some confusing request.let me clarify myself.all i need to know is which of the pulleys in drive belt area tents go first.the drive belt is new.Thanks,caug
Q451990
Your best bet is to get a mechanic's stethoscope like this and carefully (as in avoiding belts fans and other rotating items) listen to each idler pully while the car is running.
http://www.harborfreight.com/c...41966
You could also remove each pully and listen for roughness and grinding when you turn them by hand - but my way avoids disassembling and reassembling the car with a bad pully while you wait for the part to arrive if it's not immediately available.
Heath
saeedakobiakov
Car: 03 M45
wow, thats cool tool.i will buy it and give it to my man.does it really work?thank you for reply.Caug
Q451990
I haven't used that particular one, but the one I have used out of my dad's garage worked very well!
Heath
