squeaking uder the hood.
saeedakobiakov
Car: 03 M45
Hello,i have 03 m 45 with 81k on it.i have squeaking under the hood right where the all the belts are.it used to do it only when it rained, so i put new belts. now its doing all the time.My mechanic said it could be idler or tensioner pulley.Please let me know what i should do.Thanks,caug.
saeedakobiakov
Car: 03 M45
Hello again,looks like i posted some confusing request.let me clarify myself.all i need to know is which of the pulleys in drive belt area tents go first.the drive belt is new.Thanks,caug
RAGTPZ
Car: 1993 Nissan 300ZX Twin Turbo Convertible, 2010 Infiniti FX50S
You really should be checking both.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
It's most probably the idler pulley. This can happen after replacing the belts, especially if they were over-tightened. You can buy a mechanic's stethoscope (from Sear of Harbor Freight for <$20) to confirm the problem.
MikeMiersma
Car: 2003 M45
I think I might know what you are talking about. I had an inconsistent squeak that would come around when warmed up, when the ac was on or when the engine idle was at low rpm. I couldnt figure it out but finally I was screwing around and figured out it was the tensioner.
You can check it by pulling on the outermost serpentine belt to move the tensioner. You should feel it stick and hear it squeak. I bought a can of crc white grease, sprayed it in and it hasnt squeaked since. Every oil change, I put some more in. Hope that helps.
nicad2000
MikeMiersma wrote:I think I might know what you are talking about. I had an inconsistent squeak that would come around when warmed up, when the ac was on or when the engine idle was at low rpm. I couldnt figure it out but finally I was screwing around and figured out it was the tensioner.
ray
Where did you spray it exactly? I'm having the same issue myself since my belts were changed.
