Squeaking sound underneath car when clutch is depressed.
RustyShackleford
Car: Red Piggy w/Black Meshies
What does that mean exactly? I searched and this guy tried to lubricate it and messed up his clutch so I wanna just check if I need to replace the clutch or what. Thanks in advance. I have no idea of the signs that indicate the need to replace a clutch.
livinglegend2100
clutch chatter?...
silviaS13lover
Car: yellow llama onevia
well if im rite, then a chatter would most likely be the throwout bearing. it makes a lite gagagagagaga sound.
if it's squekin, id awsoom that the pilot bushing/bearing is f'd up. only one way to find out for sure. drop the transmission.
livinglegend2100
^ oh yea true story about the chatter.. havent heard it for a while, thankfully.
but yea i guess the best way to figure it out is just get under it and start lookin. maybe have someone d!ck with the clutch while your under it?
RustyShackleford
Could you guys give me some signs that might indicate a worn out clutch?
SR24DET
Car: RMS13
RustyShackleford wrote:Could you guys give me some signs that might indicate a worn out clutch?
When i blew mine, it wouldnt always go into gear when driving. Theres slipping. O and when i parked it, i would put it in gear. Then try and push the car. A good clutch will rock then stop. A bad one will let you move the car.
xX RB Xx
Car: SE3P, FC3S, FC3C.
i had a bad throw out bearing, it was a contunious noise when the clutch was pressed in.
god i cant remember how it sounded.. i cant do good sound effects
240zac
Car: 1994 240sx sr swapped convertible
i beleive a bad throw out bearing makes like a grinding squeeking unpleasant metal to metal sound.... im not sure tho
ss82480
Car: 1992 240sx Coupe
This is probably your slave cylinder, mine squeaks, even with a replaced clutch. I lubed it a bit and it stopped because the boot is torn on it. Else buy a replacement from nissan.
