Squeaking Noise
all G'd up
Car: 2004 G35 Coupe 6MT
I have a squeaking noise (sounds like a cricket) coming from what seems to be the front wheels/suspension/brakes... Only makes the sound when I'm driving...Any suggestions...
G_whizz
Car: 2010 G37 Coupe Sport
So if you park it and someone pushes up and down on your car it doesn't make the noise?
Ball joint?Suspension Bush?Control arms, bushings, and tie rods?
Tough to diagnose..
smockers83
Car: 2006 G35 Coupe
If it occurred while you weren't driving, I'd say you have a cricket hiding somewhere.
On a more serious note, I pose a question. In the event that you're driving, does the sound occur as the wheel rotates, in that it only seems to squeak in one spot of the rotation?
all G'd up
Its hard to tell b/c its not that loud and at night I can't tell the diff between the sound and all the crickets... Maybe I should just lube everything up...? I can't see it being anything too serious... I only have 23k miles
