Squeaking front suspension
Hijacker
Car: '92 240sx Convertible
'94 F-150
A few weeks ago, I lost traction and slipped into a ditch. The car was fine after we pulled it out, but since then the front passenger suspension started squeaking. I figured I'd blown my shock, so I upgraded to a set of AGX's, but the squeaking became more pronounced. Ever the restless suspension nut that I am, I realized that I had forgotten to grease my mounting bolts for the new NISMO bushings on the TC rods.
I pulled them out today and greased everything up properly and reinstalled them. The squeaking is still prevelant and now the TC rods don't look loaded properly (before the rods weren't parallel with the subfram housing). Now the rods look parallel to the housing, but the two mounting bolts have been bolted down tightly. Also, now the front suspension clunks a bit when i experience a slow load shift (such as slowly climbing my driveway)
I figure the bushings probably need to settle back in since I pulled them out, but I need to cure this squeeking once and for all
