dbaxRonin »
https://forums.nicoclub.com/dbaxronin-u181868.html
Thu Jan 17, 2013 6:18 am
Anytime I turn my wheel to the left, and am moving at just about any speed, I get a repetitive squeaking noise coming from my front left tire area (i.e. squeak, squeak, squeak). I found that it doesn't do it, however, if I turn the wheel to full lock, nor if I am turning to the right.
I thought perhaps it was just a brake scraper, but I would think if that were the case, it would do it regardless of wheel position.
I just had the front end aligned as I had replaced both front tie-rod ends. Seems it was about then that this started, but I can't imagine any work done for an alignment would cause anything like this.
Anyone have any ideas what would be causing this?
