Squeaking from suspension during low speed
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Buckeye Dave
Car: 2003 G 35 Sedan
I am experiencing squeaking from my suspension when driving at low speed going over small bumps. Are their lubrication needs on the suspension? The noise is coming from all four corners as the suspension "Flexes" going over the uneven surface.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
If the noise was just the front, I would say compression rod bushings. Since it is all four corners, I would say either shocks/struts or control arm bushings.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
i bet you money its just your front end...although it sounds like its from all over
Its the compression rod bushings. Get some new revised ones and get them installed. You'll be back to normal without that squeaky sound.
J. Dizzle
Car: 2004 Infiniti G35x
How much would it cost me to replace and install the compression rod bushings? Just an estimate for future reference would be nice... so I don't get ripped off.
tollboothwilley
depends how you do it and if you do it yourself.
If you buy new rods it will be $360 for both new. REVISED Bushings should only cost $40 and will fix the problem, but you will need to press them in. If you don't have access to a hydraulic press you can pay $60 for the dealer to press them for you. Install at a shop should cost 1 hr of labor per side.
If you install new arms at a shop : $550 ish
If you buy just new bushings and pay for labor it should be around $250-$300.
If you the work yourself, and have access to a press it will only cost $40.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
