Squeaking Breaks driving me CRAZY!!!
M35SFIREMEDIC
Car: 2008 Infiniti M35S, Moonlight White, K&N Filter, Mobil 1, Michelin Primancy MXM4's.
Hey guys , my breaks are driving me crazy. I understand that Nissan/Infiniti cars are known for having squeaky breaks, but enough is enough. I have the OEM breaks and pads. I know many of you use breakmotive drilled/slotted rotors, pads etc. I just put new breaks on the rear, and will need new breaks on the front soon. I still have squeaky breaks. What do I have to do to get quite breaks? PLEASE HELP!! :gotme
Ilya
Did you put that grease stuff that comes with most brakes on the shims?
Also, I didn't know that Infinit/Nissan was known for squeaky brakes...in both my M's they've been quiet unless worn down and needing replacement.
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
M35SFIREMEDIC wrote:I understand that Nissan/Infiniti cars are known for having squeaky breaks, but enough is enough.
I don't know about that. My brakes never squealed until the pin started rubbing. I don't know about the expensive pads others buy, but I only use Autozone gold pads. Pay once then EVERY TIME they need replacing it's free. I change once a year for new brakes even if it's not needed. Never ever a squeel.
Ilya
That reminds me...depending on the compound of the pads, some brakes are more noisy.
retho78
Car: 2009 Infiniti M35 RWD
Probably go with ceramic pads
EniGmA1987
Car: '06 Infiniti M35 Sport
M35SFIREMEDIC wrote:Hey guys , my breaks are driving me crazy. I understand that Nissan/Infiniti cars are known for having squeaky breaks, but enough is enough. I have the OEM breaks and pads. I know many of you use breakmotive drilled/slotted rotors, pads etc. I just put new breaks on the rear, and will need new breaks on the front soon. I still have squeaky breaks. What do I have to do to get quite breaks? PLEASE HELP!! :gotme
My OEM brakes sqeaked like crazy. Get some aftermarket ones, like the Brakemotive, and they will not squeak anymore when operating normally.
BlackCat81
Car: 2006 Infiniti M35x
2003 Lexus GX470
You HAVE to lube the shims and hardware otherwise they squeak like crazy.
