kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Thu Mar 08, 2012 8:39 am
Hi there, I have close to 55,000 km on my brakes and they don't squeek, although light braking does often produced a groaning sound as the pads slide along the rotors. In terms of brake pad life, that is highly dependant on driving conditions so I can't say if your pads are worn, normally if your brakes start to squeel that is the first guess - worn pads. There is actually a brake wear indicator that will make a squeek by design to inform you that your pads need to be replaced, but since your shop checked your brakes I'm assuming your pads are not worn yet.
Do your brakes squeek under light brake pressure, heavy pressure, or all times equally?
One thing I'd recommend is having a brake service performed which involves disassembling the calipers, cleaning and lubricating slide surfaces and deglazing the rotors so they make better contact with the pads and operate quieter. I just had my dealership perform this again for me and it makes a big difference. Some recommend performing this yearly, I feel it really depends on your driving conditions, mileage etc.. I live in a snowy area with quite a bit of road salt so I perform the service every 1-2 years. As a matter of fact we have an excellent How To article complete with photos showing the step by step process if you want to consider doing this yourself.
