SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Fri Nov 21, 2008 2:28 pm
If your seat is not rocking or loose you may be able to spray a small amount of high quality penetrating oil. I usually use Wurth HHS2000 I am not hawking this product I just like it. You can use something else but this stuff lasts for a very long time and penetrates into moving metal parts. Over time it turns into grease and keeping noises at bay.
I will look for detailed pics (I know I took a few a while back) of where you need to lubricate but some of these are different. Your best bet is to shake the seat and track it down, sit in the seat and find out which position causes the noise and try to isolate it. That is how I would track one down. It's most likely going to be coming from the hinge between the seat bottom and back sections.
