Squeak/Grind when accelerating
My_Nissan
Car: 2006 Nissan Pathfinder SE Offroad
2006 Nissan Pathfinder SE Off-Road 4x4
I first noticed this at a Tim Horton's drive through because my window was down and I was driving slowly.
There is a squeak/grind sort of noise coming from, as far as I can tell, everywhere. I did some testing and found it only makes the noise when I'm pushing on the gas. As soon as I take my foot off the gas it stops. It's not an engine sound it changes with speed not RPM. I also notice it makes the sound just before I stop, like travelling 5-0 km/hr whether the gas is on or not.
Any suggestions?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Ensure the transmission fluid is at the proper level. Also check the differential(s) fluid level if possible.
My_Nissan
transmission fluid is good. I'll have to jump under there to check diff fluid.
I noticed the U-Joints for the halfshaft go frequently - is this a possible problem? Should I change them and see what happens, they are cheap enough from NAPA?
My_Nissan
Diff fluid is good. I picked up some u-joints at NAPA and changed them out - no fix.
Then a Crazy thing happened. I have had new springs and struts sitting in my garage for a month now, I decided to finally make the change - while I was pulling apart the right front struts (with an impact wrench) a screwdriver fell onto the garage floor - totally mangled :blush:
No more acceleration noise. So I think I found the problem - Foreign Object Damage.
Put your tools away when your done the job and if your missing something, go find it.
asnorton44
Car: 2001 Infiniti QX4
My_Nissan wrote:Diff fluid is good. I picked up some u-joints at NAPA and changed them out - no fix.
Haha! Glad to hear you have resolved your problem :gapteeth:
