squeak/chirp
drunklowlife
Car: drinking and rocking
when im driving and going over bumps my front left wheel area starts to squeak/chirp .. it gets faster as the speed goes up.. some on said maybe its a blown shock.. im not sure.. any halp/suggestions?
Scott McLellan
wheel bearing?
NISTECH
is the sound a rotating noise or does the noise appear to be in snyc with the bumps your hitting as you drive. could be sway bar bushings or link bushings. could be tension rods blown out.
drunklowlife
seems to be when i turn i can't pinpoint when it happens but its getting more frequent so im gonna take it in. thanks guys
rico05
Car: 1992 RMS13 w/ CA18DET
If it is when you turn, could be wheel bearings.
