Neil »
https://forums.nicoclub.com/neil-u15642.html
Tue Dec 20, 2005 3:37 pm
Anybody?
changed my O2 sensor and problem remains... while changing it out i checked and the heater indeed gets 13.7v so that brown wire thing is out of the question. didn't drive it around but the idle is a little better. instead of bogging and revving, it'll hold a fairly smooth idle but randomly go up like 300rpm's or so once in a while. It will still stall if I flick the throttle though. The old O2 sensor had a thick layer of carbon on it indicating it's wwwaaayyy too rich.
Still havent checked for boost leaks but ive said before, it runs like a bear with no breakup thru the revs while being spirited. just cant hold a speed without violent bucking and idle is messed up.
at idle i don't think the turbo is even spinning fast enough to pressurize the intercooler system... i'd think there would be a vaccuum and a leak would let air in which would lean it out, not richen it.
Gas pressure on original FPR at idle is about 42, 43psi. Have yet to install my Walbro but I dont even think I need it anymore, as the oem pump is apparantly capable of supplying enough gas to make the level go down a quarter tank in like 25 miles.
Pulled the plugs off each injector and idle dropped proportionatly and sounded the same between all 4.
Remember when I set my TPS to .50v? went to double check that today and it's jumping around between .35 and .55 still sort of within range but i dont like how it moved on me. Holding a particular throttle position it moves around just as much of a range. Probly not the source of my problem but im still going to get a new one cuz i dont like it.
I haven't had the ability to swap out MAF sensors nor have i checked its voltage. What SHOULD it be reading?
