ProudNissanFreak »
https://forums.nicoclub.com/proudnissanfreak-u121950.html
Mon Apr 20, 2009 7:02 am
Hmm, the fuel pump seems to be fine, so it's probably the spark plugs that need replacing. I don't believe the previous owner replaced it, so I'll get on that.
Also, VMPhil, you mentioned moisture going into the engine, which could also be the problem since it's rained pretty heavily out here for a couple of days. I'll check this out too.
Thanks guys!
