VG33QX4 »
https://forums.nicoclub.com/vg33qx4-u162332.html
Sat Oct 09, 2010 10:08 pm
so today i noticed that when cruising down the interstate, my q started to buck slightly as if it was misfiring. the only check engine light i have is for the IACV, i have been driving with iacv cel since i got it running 4 months ago and it never bucked or misfired just idled a little lower than it should. Now i have a brand new distributor, original spark plug wires that look worn out and are the likely culprit.
the best part is, if i floor it, it doesnt miss a lick and goes just fine.
new plugs
new distributor
new fuel filter
maf is clean
air filter new
throttle body clean
the reason for this post is to ask, does the idle control valve have any function other than at idle, or should i say is it possible for the iacv to affect driving at a constant speed?'
i show no codes for misfires at this point on my scanner.
