nuts510 »
https://forums.nicoclub.com/nuts510-u34687.html
Sun Dec 24, 2006 6:52 pm
you probably have an air leak somewhere in the air intake system, make sure all your hoses are buttoned up good and tight if it's and intake hose check it for leaks because of this fun I made myself a little fitting to put an air flow meter and then I'll blow air in the intake with a pressure regulator in that way I can duplicate boost while the car is in the garage also ran into bad blowoff valves that only leak under boost to very annoying problem to run down.
