sputtering 89
jacc65
I have 89 240sx w/ ka24 between 23&2600 rpm car sputters like no power or fuel before & after ok what can it be? I checked all sensors & did cpudiag with no results any ideas anyone?
VeloceDrift
Car: 1993 Nissan 240SX S13 coupe
1995 Nissan KA24DET
double check your MAF. 240's are hella picky with the MAF sensor.. i was driving the other day and my car runs great and all of a sudden it started to die every time i stop(which is pretty common with 240's anyway it turns out that all the bolts on my air filter came loose and just because of that it ran like ****. so check that too.
Sonikfuri
Car: S13 Coupe
check ur tps sensor...you might need a new one too.
rotorimp
Car: 02 Xterra, 60 IH Metro
+1 for the TPS--especially if it only happens in a particular throttle range.
