sputter problem with ka-t
cameron14
i bought a s14 with a ka-t and ever since the third day i drove it, the car doesnt boost or somtimes idle the same... at about 4.5 k when i hit boost it sputters and cuts off pretty bad. it feels like sparks plugs are goin out but they arent i checked. it also backfires when i hit boost when it sputters.
somone please help
J14cm7
Car: 95 240sx S14 SR20det
Sorry cam i should have commented on this thread instead of your other one. Like i said your def running rich as f*** when you hit full boost. Although it may not be a boost problem it could be your MAF I have read threads where as the RPMs went up there car would sputter and run rich.
Are you spiking or have bad vacuum?
cameron14
J14cm7 wrote:Sorry cam i should have commented on this thread instead of your other one. Like i said your def running rich as f*** when you hit full boost. Although it may not be a boost problem it could be your MAF I have read threads where as the RPMs went up there car would sputter and run rich.
idk ill check the sensor but how would i check it?what other symtoms should i look for
zeause
Sounds like fuel cut to me. Does it have a walbro in it? Check your fuel pressure. How is the car tuned or are you just runnin a FMU? Does it smoke when it cuts? Probably white smoke...
Chris28
Car: 92 s13 KA-T
KA-T section would be of more help, though you might have a thread there too.
What are you using for tuning?Have you checked for boost leaks?What FPR are you using?What plugs are you using?Pre-turbo (post maf) plumbing airtight?
