mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Thu Jun 12, 2008 11:54 am
Could be many things, but sputtering is usually an ignition issue... Such as coilpack(s) failing under load or bad spark plugs.
I would take out all the coils boots and plugs and inspect everything for cracks or fouling.
What plugs are you running and how old are they? Does it ever miss at idle? Codes stored on the ECU? What is your fuel pressure & do you have a FPR? What is your base timing set at?
We need more info...
