You could get the crank cut down or get another 8cw crank. If your going to rebuild it also change the oil pump and bang out the pan before you reinstall it.240sxcl50 wrote:I need some help here, im buying a sr20det it has a spun rod bearing the motor isnt locked (yet), how much damage can that cause? Im rebuilding the bottom end im just wondering if its a lost cause?
The lower oil pan has a spot where the pick gets the oil. If that is smashed it will cause oil starvation and you will be back where you started.240sxcl50 wrote:Bang out the oil pan? what does the do for me?
