Spun rod-bearing?...No, but it felt like it
cullenj76
Car: 99 Q45t 04 SRT-4
Well, I was on my way home from work yesterday and everything was as usual: no AC because my n2o line got in a fight with my high-pressure AC line and the n2o line definetely won, uncomfortable friggin' driver seat due to high miles, listening to some John Coltrane trying to relax and then it happened. My motor started shaking violently and vibrating like my motor mounts had turned to spam. Fear set-in immediately because: 150k miles on my original motor, I get a little spray-happy sometimes with the n2o, and although I do take VERY good care of my car, let's face it I am a track whore:)
I felt the all too familiar feeling of a spun rod bearing that I remember quite well from my sr20 that I blew. I pulled over to the side of the road, checked everything. No leaks in the intake plumbing, no disconnected sensors, etc. So, I drove home in 2nd gear at around 3k rpms to put less stress on the motor. When I got home I realized that my A/F and nirous pressure guages were working, nor where my nitrous and bottle warmer l.e.d.'s
Yadda, yadda, yadda. I reset my ECU and everything was fine. Back to normal, and I assumed that since I've been having electrical issues, my signal feed wire from the ECU to the A/F gauge got some bad voltage feedback or something.
Well, I woke up this morning and started her up around 5:30am, let her warm up for 5 minutes like I do every morning. As soon as I began to back out it happened again. So I just said oh well and reset my ECU, but no worky. So I pulled all my plugs, checked my MAF, etc. and was baffled. None of that worked, so I began to troubleshoot a little by pulling all the wiring harnesses of of the coil-packs one at a time to see if one of them was bad because I did not have my multimeter on me. Those were all good. Then I followed the same routine with my injectors, and blammo it's the third injector from the right on the front bank of cylinders. I pulled the harness of the injector and the car was running exactly the same as it was when it was plugged in. Found the problem, but It's now 8:30am, I am 2-1/2hrs late for work, and I am stuck with no ride(resentment towards my brother who's driving my SE-R setting in). So I called my trusty neighborhood nissan parts guy;) who's name I will not disclose due to possibility of his phone ringing off the hook from people wanting his discount since he's a member here. I guess I'll start calling junkyards.
audtatious
Wow, that sux. Then again, as you know, it could be much worse.
Nice troubleshooting!!!
cullenj76
Yeah, that's what I was thinking. It could have been one of the REAR bank injectors, and anyone who's ever worked on any VQ knows the trouble with those. LOL
audtatious
That's the truth. You can barely even see those little buggers.
Damn shame I have to leave for Dayton within the next 1/2 hour or I'd offer you a hand or a lift if you needed one. :(
cullenj76
Dayton Ohio? For work or what?
audtatious
Yeah, I have a lunch meeting with Lexis Nexis and have to be there by 11:15. I will be in Cinci Tues-Thurs of next week. That's why I have 60k on my car already....
cullenj76
new fuel injector, new coil-packs up front(thanks Dave), and good........for now(fingers crossed)
turbo6
Car: '05 350Z Turbo, '98 SC300 9.3@156, '99 SC400, '02 Police Interceptor
did you check the alternator as discussed?
cullenj76
yep, checked the alt. and I'm getting a steady 14.0-14.4. That is ALOT stronger than I thought it would be consideriing it is an alt. with 150k mi. on it. I think a data-logger would be useful to monitor surges which you really can't do with a multimeter, I just need to get a PDA.
