Spun Bearing on L28?
A home for 1983–1989 300ZX owners!
omg240
Car: 93 240sx vert, 1991 300zx TT
Im looking at purchasing a 240z that has an L28 swapped into it. It has atleast one spun bearing. Can the bearings be replaced properly without rebuilding the entire engine?
Also, the car has been turbocharged. Can I just use OEM Nissan bearings, or is there a stronger aftermarket alternative?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if a bearing has spun there is a reason, and it should be torn down and checked otu at the least, nissan bearings or any name brand aftermarket bearings should be fine, the nice thing is the L6 uses 7 main bearings! so it spreads the laod and they take a lot of abuse
or just find another L28 to swap in, as for turbo, was it a stock L28ET from a 280ZXT? was it a turbo tom carb'ed turbo setup? look at the bottom of the block on the crivers side kinda below and forward of the mount, the casting number should be N42 or F54, then look att he head between the spark plugs for #1 and #2, should be a casting # there like N42, N47, P90, or P79
is it now carbed ro injected? SU? webbers? downdrafts? sidedrafts?
what's your goals for power and use? lots of potential here, it cna be as wild or mild as you like
Return to “300ZX (Z31) Forum”
