No offense to your friend or questioning his integrity, but from the way you explained it, even though you did everything right, this engine already had a problem with its bottom end. Just because it sat doesn't mean everything is supposed to stop functioning. You say you turned the engine over till the oil light went off, but it still knocked? That indicates to me that it was already screwed before you took ownership.cadence_1 wrote:Ok.. so I bought a motor off a buddy of mine that he ran in his own car for about a year or so.. He then got a differnt one and parked this one... It say for an additional year or so before I bought it and put it in my car.
I finally get everything together and start it yesturday(turned the car over without starting till oil pressure light went off) and I have what apprears to be a rod knock?
Now I have read that a lot of people have run these things straight out of oill.. it starts knocking and they put some oil in and be fine? I of course wasnt out of oil but do you think there could be any other explaination for this noise. It does very a bit w/rpm and I can really make it make the noise when I crack the throttle slightly from closed.. and I am really slightly. I tried making the noise and then pulling off individual cylinder coil packs to see if the noise went away and all though it may have gone down slightly it wasnt a definitive(I couldnt match the knocking point exactly while pulling off the coil)?
In any event I am just looking for anyones opinion on the subject.. your experiences with spun bearings or rod knocking? What you did? What you found out? It just bugs me that this motor ran fine a year ago and now all the sudden it has a rod knock the first time I start it up.
Finally if this is a case of some new bearings.. at the very least.. where is a good place to get some.. Is nissan the only place to look or should I bother with aftermarket and how much do bearings usually run for these cars?
Lots of questions.. I know.. I have searched.. but "spun bearing" and "rod knock" only return like 3 results..
thanks.
SOrry this post is so long.
The best way to check or change your bearings is to remove the engine, put it on a stand and take your time with it. Sometimes you can get away with just changing the bearings, sometimes they may last a short while, sometimes they may last a long time, and then again, sometimes machining is the only option to correct out of spec components. If you pull the engine, may as well do it right and get everything refreshened. If you take the cheap route by just changing the bearings, good luck with that and I truly hope it lasts a long time for you.cadence_1 wrote:I just saw that thread.. unfortunately I am at work and we have pretty strict streaming policies here.. so I am definately going to check it out later tonight and I will let you know.
thanks..
Is there a good tutorial somewhere on changing bearings.. what I shold check .. how to do it.. other than the FSM ofcourse..
So you're a lefty, huh? I guess you could get hurt spanking the poor monkey with your left limb:rotflmao (just having some fun with you, Tim) .r34 gtr wrote: sorry for the terrible spelling but i broke my left arm and typing fast one handed sucks.
