hpdrumakk »
https://forums.nicoclub.com/hpdrumakk-u17181.html
Fri Oct 28, 2005 11:25 am
so heres the deal this might be a little long but PLEASE bear with me and help me figure this out.
heres the history of the motor.about a year ago i rebuilt it after a spun bearing on the 3rd cylinder's connecting rod. the bottom end was completely rebuilt with topline parts, the block was honed, hot tanked, decked, and crankshaft and rods were machined. there was no wear on the cams or head so i replaced the valve stem seals and did everything by the book. it started on one crank of the starter after i put it together and i broke it in under 3k rpms for the first 3000 miles. after the 3000 mile mark i took it down the beltway and topped it out and it ran beautifully. i came home the next day and it was smoking out the exhaust at idle and soon after suffered a blown head gasket. even with these problems it still had no performance issues what so ever.
i purchased a used head from a reputable shop (light speed performance) here in houston and sent it off to the machine shop, had it milled, pressure tested, checked for clearances and rebuilt. i pulled the old head off put the new one on, changed the timing chain, and immediately suffered performance issues after start up. it was fine from idle to 3k and after right around there performance wise fell flat on its face. it still smoked on idle and i tried everything i could think of to figure out what was wrong with it. a compression test showed all the cylinders were good and i rechecked my valve and igntion timing several times. so prom weekend i went to galveston and drove it up and down the beach a couple times and the next day i got on the freeway to come home got about 30 miles and the #3 connecting rod bearing spun again!
so it sat for a while and i just pulled the ka out and stripped it down and noticed gold metallic flakes all over the bottom of the oil pan (which i had just thoroughly cleaned when i changed the timing chain) and every lubricated surface on the inside of the engine was scored. cams, bearings, cylinders, PISTON SKIRTS, and crankshaft (to a lesser degree) were pretty tore up. i found a larger piece about the size of the end of a pencil eraser and it looked a lot like the same material the throttle butterfly is made of (brass im assuming). and strangest of all in the combustion chambers every cylinder showed signs of running lean except the #3 cylinder which appears as if it was running incredibly rich.
i am thoroughly stumped on what would cause a perfectly rebuilt engine to self destruct like this. and i sure as hell cant figure out what is made of brass that could flake off into my oil pan like that.
i have high resolution pics but dont know how to post them
thanks in advance,-jason
