SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Mon Apr 25, 2005 7:18 pm
A given wheel has two major parts. I'll shorten and condense as I'm tired and want to hit the basics
1. the wheel disc. This is the center / face of the wheel. Cool wheels have a mesh style.2. The wheel barrel. As the name implies, this is the round part that looks like a hoop.
There are many different techniques employed to build an aluminum wheel. For this quickie, we'll focus on a simple version of a two piece unit.
A wheel disc can be pressure cast, cut from a solid block of aluminum(CNC machined, billet) and / or forged. Again several methods.
A wheel barrel when mated to a forged disc, is often spun or rolled. This can do a couple things:-save weight due to thin rolled aluminum as opposed to a casting-often be too thin to withstand severe use.
Most manufacturers over-engineer a wheel so it will be able to withstand any and all abuse thrown at it. Some wheels, for example a "race only" drag light wheel, is designed to be as light as possible, with little or no consideration given to everyday use and abuse.
The above is where we find a wheel that could be used for street, but may not hold up as well. A light but super strong disc, mated to a barrel that is as thin as possible to cut weight at the cost of longevity. These would be what a given manufacturer would label "race use only" etc.
Rolled barrels that are extremely thin in the name of weight savings have been around for some time now. In 1998 I hit a pot hole that claimed one very nice polished Weld Drag Lite. Luckily we were in with a wheel restorer who was able to do top notch repair work. Those wheels are long gone now...as are my hot rodding days.
[Chet please edit inaccuracy due to sleepiness]
