Jberger »
https://forums.nicoclub.com/jberger-u226.html
Tue Nov 05, 2002 12:30 pm
Use compresses air if you can, that will usually clear the lines unless something crawled down there and died (actually happend to me in a BMW).
You can also use a flexable rod, like a fish tape, but you risk rupturing the line somewhere inside the frame. Either way, that should solve the problem. Also make sure your sunroof is aligned correctly at close, sometimes you end up with a crack that can leak in heavy rain or if you park at certain angles.
