sprocket
RagingPanda
Car: 78' 280Z
the crankshaft sprocket should slide in easilly or did you guys hammer it in. I got it from a 1988 Pulsar SE. or was it 1989...i totally forgot but that's not the point.
dvd
i had to do a little hammering.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
They should all fit. With an interference fit, shouldn't slip on.
The CA20 one is a smaller diameter hole.
If it looks close, run some steel wool over the mating surfaces and hit on with a rubber or plastic mallet.
But it will need a tap to get it on.
Akihisa
Car: 300zx, Italjet Formula 50Lc, Italjet Dragster 180
I just set one on a wood stove for a couple minutes and it slid right on the cold crank.
RagingPanda
Car: 78' 280Z
this might sound stupid but what's a wood stove? do you put the key in first?
F3600
he heated the sprocket a litlle to expand it.
Akihisa
It's a stove,but instead of using gas or electricity it uses wood. It's the only way my shop gets heat so that's what I use.
