springs vs. coilovers ( w/ stock shocks n struts)
wanabedriftking
Car: learning how to drift
wich one is better?i heard coil overs are boucy but i also heard thats only because of how they get adjusted? i ordered a set of coil overs for my s13 just curious of other peoples thoughts
and how should i set the coil overs for drifting? front hard back soft???i dunno any help would be appriciated
thanx
(todays my 18th b-day)
droptopsilvia
no stock struts with new springs, not only will they all be blown in a week, but your back will thank you, not bouncy, harsh + jarringwould be the best explanation...order new struts and then put them on as one.
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
you must be referring to those "coilover" sleeve type kits, which are total and utter crap. They are the last thing you would want for drifting. Nothing like a slipping and cracking sleeve when you are heading for a cement wall at 50+ mph. you'd be beter off with some simple sport shocks and stiffer springs, or even stock over those. what you really want to fully adjustable REAL coilovers. They are getting more and more affordable every day. maybe save for those, or settle for shocks and springs. springs arent much good with better shocks though. If you have to, get the shocks first, then springs. I like Koni adjustables, KYB agx. Then there are tons of springs out there to choose from.
