Springs???
fresno240sx
i wana buy some springs for my car..i was thinking of 1.8 or 2.0..which one is better? any ideas?
Vernal
Car: (RIP) 1990 Hatchback 1989 Hatchback
fresno240sx wrote:i wana buy some springs for my car..i was thinking of 1.8 or 2.0..which one is better? any ideas?
I have a set of eibach sportlines. Front and Rear. Their website says 2.2 inch drop in the front and 2.1 in the rear.
fresno240sx
how low is your 240 on 2.1 and 2.2 inch drop?
Vernal
I dont have any pics of my car cuz its RIP. The car sat about an inch above the tires.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
Vernal wrote:I have a set of eibach sportlines. Front and Rear. Their website says 2.2 inch drop in the front and 2.1 in the rear.
id say eibach as well, my friend has those on his car and he says he likes them
Brandon93240
Car: 1993 240sx
Philsnotfalling has them on his hatch, they look good now that he got his Advans. Just low enough but not crazy, and it rides pretty nice.
Emperor_Tha
damn i need a spring drop of 4inch in the front. so much wheel gap after the sr was installed
all4sho
Car: LOTS of Nissan's
i got a set of cheap *** nopi brand on my s14 and i like them they set it right with 18's and don't ride bad with stock strut's
mval123
Car: 91' 240 hatch
I had sportlines on my 1st 240, looked good and handling was awesome. You just doing springs or swapping out the shocks struts also? you should be ok with anything under 2" depending on how old your current setup is but an agressive drop will blow the old stockers out pretty quick (a lesson I learned the hard way)
TKE SigO 258
Eibach and Tein have good reputation.
mirochuki13
Car: 1992 Nissan 240SX Hatch
how quick did your shocks blow?
TKE SigO 258
3 months max
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
I have the Sportlines (installed by previous owner). They are nice for street driving, but when you push them, they can be unsettling bc of the progressive design. I have them on KYB-GR2's. just about any strut/shock will blow faster than normal (stocks really fast) on these bc of the drop. More than an inch of drop and the S13 240 bottoms out on it's suspension, so just keep that in mind.
jbarbaresi
Car: 2007 Nissan Sentra SE-R SPEC V
what's the major difference between the sportline and proline by eibach other than the .5 inch drop difference?
generic808
Car: '08 Infiniti G35 S
'10 Infiniti EX35
The "Pro-Kit" is also a progressive rate spring with only a 1" drop. These were made specifically for street. They were designed for use with the factory suspension components. I personally think these are the best "all-around" springs unless you plan on racing. I ran both Pro-Kit and Sportline on my SE-R and I think the Pro-Kit is a much better ride. Of course you only get 1", but your bladder will thank you
