Q45tech wrote:Aftermarket cheap non adjustable shocks [Tokico Blues, AGX, etc] are just 10-15% stiffer than oem when new[designed to make up for oem bushing wearout] ...........they really cannot handle the 15 x 2 ~~30% increase is inch pounds a stiffer minor lowering spring [stiffer over shorter travel] creates for long.
Springs by themselves cannot do much for handling in the sense of increasing G forces before tires wash out [oem size load index are always undersized to create front understeer].
Tires are 85-90% of handling ---------suspension is the rest, assuming it is decent to begin with.
Lowering 1" at best proves a 2.5% increase due to lower center of gravity....less weight transfer to tire but that is about all any lowering can accomplish because the bump steer changes so radically making handling worse!
A soft fast wearing performance tire can improve things 5-7 even 9%.
Q45Tech is exactly right
If your'e running a tire that's not up to the task, i.e. like an a/s tire, or something crappy in general. You will break traction much easier than you would on stock springs. It's better to save up for the coilovers (if that's what you really want) than to compromise your suspension by throwing lowering springs on tired OE shocks. The first step you can make in better handling/braking is better tires. There's a nice list Exar has in the Tire sticky.
