Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sun Apr 03, 2005 9:00 am
I'm going to tell you to search, simply because this has been discussed so many times. Also, read the big-azz "attnetion" sticky as to why I'm close to just deleting your post. Never the less, here's the quick and dirty:
S. Tech/AGX combo is probably the most used, and suggested combo because it works exreemly well for street cars
AGX/RS*R race is better for more spirited/track duty cars that don't want to go coilovers, but you have to set the AGX's on higher settings because the springs have a higher rate.
Koni's shocks>KYB AGX, but don't offer adjustability in the rear IIRC (on the car).
KYB GR-2s are good for a 'semi-stock upgrade' but shouldn't be paried with anything stiffer than an eibach prokit, because they'll fail prematurely.
-Chet
