NolimitZ32 wrote: ↑Thu Jul 09, 2020 6:11 am
I'd have to echo what Z1 and SZ told you, beyond not needing the infinite adjustability you'll end up spending more on the coil-overs than on a set of springs and shocks. Were either of those two vendors unable to recommend a set of springs other than the Tiens? I know that CZP has Megan Racing springs available but those are 2" drop all around. you can always look at getting custom springs made, there are more than a few companies that do that.
Yes S-tech and H-tech are available.
The S-tech are F 1.38”. R .83.
Rear is good. Front way to low.
H-tech F .79”. R .24”
Fronts look good. But back is still to high.
Someone had mention I look at Ground Controls coilover conversion kit. Never heard of them or a “ conversion kit”.
Looks like it comes with some Red Eibach springs and you choice the shock.
I contacted them for more info.
Someone said this way I still have Eibach springs and can choose my height and adjust my shocks
Sounds like a full coilover to me.
I don’t know what kind of drop the Eibachs give. They are much shorter then the old pro’s that were .80”.
