springs rub against firewall
GuSpeed
hey guys..
i just installed some inner and outter tie rods. with the increase in steering angle, my kyb agx and tein springs, rub against the firewall or undercarriage. whatever its called.
anyone had this problem?
thanks
ebfogg
Car: 89 240sx coupe
are you sure its rubbing on the firewall. It doesn't seem possible, have you had the front end aligned? is the tire rubbing, and not the spring strut combo? do you have pictures?
adrianfromthecastle
Car: 1992 Nissan 240sx
please post pics of what you're talking about.
GuSpeed
I've tried looking, but cannot really see. I just installed the inner and outter tie rods and this problem occur. I'm thinking since the tein tie rods are adjustible and it has the spacers for increase angle, the wheels are rubbing when turning..
I'm just going to get an alignment and see what happens after that.
GuSpeed
got an alignment and it solved the problem.
94_240sx
Car: 94_240SX
When you install aftermarket suspension stuff, you have to compare OEM and aftermarket parts side by side and keep the same length. It sounds like your tie rod end was further out, so angle was changed and tire was hitting the firewall.
