springs question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
br4dysays
Car: 06 Nissan Altima SE-R
Okay, few questions...
I'm going to buy some Tanabe springs when i get new tires / rear shocks, what else do i need? alignment shims? How much would a shop charge to do the springs? I'm assuming they wouldn't charge more to replace the shocks while they do the springs...I need new shocks anyway so figured I could get them both done@ the same time for cheaper?
any input?
blindsnyper
Car: 2007 versa
if you have a jack, some stands, a rented spring compressor, commom hand tools, and a helper you should be able to do them yourself.
a shop would probably charge around $80 an hour and probably 2 hours.
NODES
Car: 2007 Nissan Versa SL (Blue)
blindsnyper wrote:if you have a jack, some stands, a rented spring compressor, commom hand tools, and a helper you should be able to do them yourself.
I heard the rears are a B1CtH to install.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
Changing springs and struts/shocks isn't hard. Just be careful and use common sense when doing the front springs. Do not even think of loosening the strut piston nut until your springs are compressed and even then do it away from your body. A loaded spring can send you the hospital.
NODES
Shad0wXCalibur wrote:Changing springs and struts/shocks isn't hard. Just be careful and use common sense when doing the front springs. Do not even think of loosening the strut piston nut until your springs are compressed and even then do it away from your body. A loaded spring can send you the hospital.
or grave
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
the rears were the easier of the 2 to install...
br4dysays
haha well i would attempt to install them myself but i'd rather save myself the hassle, i put in the CAI a few months back.
I need the rear shocks replaced anyway & was going to pay for that to be done so i figured if they are doing the shocks, might as well do the springs @ the same time, might get some kind of break?
probably going to have it done when i get new tires, so itll be about a 700+$ adventure
Shad0wXCalibur
May I ask how many miles you have? I'm puzzled by how you already need shocks replaced.
br4dysays
about 51k.
idk how either, i was told this by a local joint, supposedly they are leaking fluid or something...
Return to “Versa Technical Discussions”
