dickie »
https://forums.nicoclub.com/dickie-u32299.html
Fri Sep 07, 2007 10:47 am
i guess you could say that if oranges were comprised of apples...
a coilover is simply a spring and shock combo that is combined and constructed to provide adjustment on several different levels. basically, a good shock and spring combo can function as well as a coilover if the spring rate and dampening adjustments are optimized for the specific use, it just lacks the versatility a coilover provides. you can swap the entire assembly with different parts to produce different results.
please dont spread misinformation like that again.
