8k = 448, So 450 lb Springs6k = 336, so 300 (Not sure if any one does 25lb increments or not), 325, or 350 lb springs4.7 = 263, so 250lb springs
ashibah83 wrote: and if your after those types or stiff spring rates you might want to look into a good set of coilovers or a spring strut combo matched spring rates to valving, if you want that try contacting koni and ground control adjustable spring rates, ride height, and custom damper valving
What he said.
Also, I doubt very seriously that Koni Yellows would need custom valving for any of those spring rate. I think Koni Yellow OTS unit can handle 500lb or so springs (I could be wrong on that though, but I am fairly sure it is in the neighborhood). They may need to be rebuilt a little more often, then if had them re-valved. But I would think they could handle them. Nothing a call to Koni couldn't answer fairly quick. the only thing that sucks about the Koni Yellow OTS units, is adjusting the rears.
