Spring Rates
starfireS14
Im a bit clueless about spring rates can someone explain them to me for example 9/7 vs 7/5.
Nismo_Freak
Car: 89 Nissan 240SX
9/7 means... 9 kgf/mm front spring rate, 7 kgf/mm rear spring rate.
starfireS14
Nismo_Freak wrote:9/7 means... 9 kgf/mm front spring rate, 7 kgf/mm rear spring rate.
so the higher the number the stiffer the springs are?
Nismo_Freak
Yes
1 kgf/mm = 1 kg of force to depress the spring 1mm
starfireS14
thanks for clearing that up for me.
Nismo_Freak
No problem
