I think the 8kg/mm converts to about 448 lbs, and the 6 to 336lbs--so I wanted to get some input from some folks before deciding which way to go over the winter.naed240sx wrote: I think that 8/6 kg/mm rates are what most people find to be great for track/autox, or higher If the car is never going to be street driven. .
you got it man stock is 2....its a pretty big step up. I have 8/6 and its stiff, in fact on rough roads you can tell the tires loose grip some times from the bouncing. but overall they aren't too bad for the street, and are pretty nice on a smooth surface....Vettedrmr wrote:Just for comparison, what are the rates in KG/mm for stock springs? I looked at the suspension FAQ, and it said the stockers were 2, IIRC. If that's true, that's an enormous difference!
Thanks, and have a good one,Mike
-Codeman05 wrote:i run a 9/7 on my k-sports. it is extremely harsh and you need to adjust the shocks stiffer to prevent a lot of bounce so that makes it even worse.
LOL--Hey Lew--I am going to sell them to you cheap!--Just think of me as test driving parts for AutoX for you.ignigknot wrote:If you do coilovers what are you doing with your old springs?
That is part of the battle I am fighting. The upper level ones are $$, so I wondered if they were worth it? Or am I better off converting my Konis to coilovers and playing with spring rates. (already have the konis, coilover kit, camber plates and extra springs--I am still less than most coilovers.Codeman05 wrote:91rs13 they are good on the track for their price. the more expensive products that i have driven with on soem of my friends cars (zeal, buddy club, kei office) performed better but you have to pay twice as much for them so its a good balance. with some sways and new bushings they feel just right to me.
I have considered them--they seem to have good feedback. But I do think I am going to get the coilover kit and camber plates and convert my Konis--It seems like I would have more flexibility with spring rates---where as most of the coilovers seem to be in the 8/6 or 9/7 range--without many other spring options.nismofly wrote:have you looked at kts coilovers? quality and performance of the higer priced units, for much lower price
I feel spring rates should be based off the weight of the car, and how you will drive it. The car is autocrossed and used for track days. Originally I intended to drive it on the street, and to events. However I decided to keep my trailer and tow it to events. I will drive it on the streets, but am not concerned about how rough the ride is--as it is not a daily driver. On the AutoX course runs on V710s and Toyo RA1s for track days.nismofly wrote:what else could you want? anything more than that isnt worth it
7/5 or 8/6 are your best bet
Just to keep facts straight, the Project Silvia your'e referring to is Coleman's car. He's running 6F/5R for springs because they couldn't get the skidpad numbers out of the 8/6 combo. They thought it was too stiff as well. They couldn't pull 1g until the switch....naed240sx wrote:Forgive me, but still do not see the truth in that. Take for example, The sport compact car s13. It has 8/6 jic coilovers and falken azenis tires, and pulls over a g on the skidpad. Do you really expect me to believe that the car would pull a greater number of g's if it utilized softer spring rates? I think many people's claims that 8/6 setups are overkill are based on pure opinon and hypothesis. Many people have cars running these setups that are performing extremely well, and have actuall #'s to back it all up.
Owned...yea. Seriously though, without r comps, stiffer springs just cause problems. Our cars do not need 10/8 or even 6/8 rates on any street tire, no matter where you drive. The weight transfer is too fast, the car is too sensitive to any imperfections in the track, and you end up with a skittery car. The tires wash out way before the springs come close to compressing completely. Its just nota good system.veilside180sx wrote:Just to keep facts straight, the Project Silvia your'e referring to is Coleman's car. He's running 6F/5R for springs because they couldn't get the skidpad numbers out of the 8/6 combo. They thought it was too stiff as well. They couldn't pull 1g until the switch....
