Ceptos »
https://forums.nicoclub.com/ceptos-u840.html
Tue Apr 12, 2005 7:16 pm
the springs themselves do not control the speed of the weight transfer, this is done with the damper. by changing to a stiffer spring without increasing dampening power, it will make the weight transfer quicker and give you a quicker response. this is not your only option. maybe a set of roll bars are what you are looking for, since it sounds like you are not concerned with having stiff springs. if you are interested in generally improving the feel of your front end, you could also look into bushings and maybe control arms. these will make the front end more solid and react to your input with greater precision.
the rsr's spring rates are probably too much for an entry level damper, they would wear them out at a faster rate, and matching a good damper to a spring is essential in the overall setup of the car. if you do want the stiffer spring, i recommend a new set of dampers as well. the stiffer springs would reduce body roll (which would satisfy the urge to buy roll bars for a little), and also not give as much when hitting bumps, protecting your lowered car.
a spring too stiff for its damper or worn dampers were probably the reason your car had such a quick response to begin with. you put on a well matched spring and damper pair so the response would seem to drop. i am suggesting all of this without knowing what you consider to be a quick steering response, but it is worth noting that you can easily make it too quick. weight transfer needs to happen smoothly, not with lightning speed. you may be judging the cars response at cruising speeds, which does not give a good representation of its true characteristics.
and if you are familiar with oversteer/understeer and the result of toe and castor change, these will also have an affect on steering response.
Modified by Ceptos at 2:11 AM 4/13/2005
